70Nightmare
New Member
Nothing still at friends shop getting the efi swap done
"Mach1ne" said:After working on phone systems for 60 hours this week I decided to go down to the basement and trash out my GT500 track wheels. Of course there was the added benefit of breathing in lacquer for few hours. Buzzed painting is drunk painting.
Got two of them done today. Hit them with a pad to scuff them up and then used Krylon semi flat and then Krylon satin clear. Not sure how they will hold up when it comes time to get new tires. We will see. The satin clear may have not been a good idea.
<img src="http://www.stangfix.com/testforum/gallery/9/217-080112171931.jpeg" />
That's assuming a lot isn't it ??"silverblueBP" said:They'll be all chipped the first time I pass you and kick rocks all over them!
"70 StangMan" said:That's assuming a lot isn't it ??
"silverblueBP" said:No, I pass Skipper all the time. Be a diff story if he'd sell the PJ and get a PT!
"Mach1ne" said:Ouch. You try to be nice to a guy and this is what you get. Your day is coming mister. Just wait. With Parnelli Jones as my witness, I will pass you by with such vengeance that your underbritches will be full of shart.
:yah :yah :yah :thu :thu :thu :yah :yah :yah"Mach1ne" said:Ouch. You try to be nice to a guy and this is what you get. Your day is coming mister. Just wait. With Parnelli Jones as my witness, I will pass you by with such vengeance that your underbritches will be full of shart.
"Kats66Pny" said:Not a bad ground. Not bad relay. All that stuff was checked, which is why the guys working on my 03 are confused why they won't work.
Positive (+) wire to one side of light bulb, Negative (-) to other side of light bulb. Positive (+) attached to 12 volt source, Negative (-) attached to ground............light bulb lights. If no lighting happens, either (+) or (-) is missing from the bar fight
You might be able to switch the fog relay with another on the car to see if it helps.
http://www.moddedmustangs.com/forums/audio-video/84165-how-keep-fog-lights-high-beams.html
Tell them to read that, should help the troubleshooting as you can bypass the fog light kill switch (with high beams on). The cut out drops the ground to the fog lights. If your relay stuck shut, the ground will be interrupted and not allow the fogs to work.
"70 StangMan" said:Cars have heaters :shrug
Why would that matter ??"silverblueBP" said:Only if they leave the garage!
