Thanks brother!!Nothing makes a car guy happier than that first start. Congrats Chris.
I sure do know the feeling and can relate.
Very cool!
Chris
Very cool!
Thank you!! We shall see.That's awesome glad that you got it sorted out. It definitely sounds healthy.
I had a similar thing. My Dakota Digital cruise control was randomly shutting off for years. I chased connections throughout the whole system. Then finally I went back and checked the ground to the main cruise control module and I had a bad connection. Fixed that and everything is now fine.She’s alive!!! After chasing what I thought were ground issues(sanding the block and tiny spot on the firewall with 80 grit…
Started pushing connections and then pulling on wires and found a bad crimp. Only 6 hours later after my first attempt lol
Here she is.
So so happy.
Chris
It’s crazy sometimes, I’m not good with electrical regardless. I know the basics but far from even an apprentice.I had a similar thing. My Dakota Digital cruise control was randomly shutting off for years. I chased connections throughout the whole system. Then finally I went back and checked the ground to the main cruise control module and I had a bad connection. Fixed that and everything is now fine.
It sounds very, very healthy!She’s alive!!! After chasing what I thought were ground issues(sanding the block and tiny spot on the firewall with 80 grit…
Here she is.
So so happy.
Chris
I was gonna say buff. Somebody probably gets all the ladies. Leave some for us!You look freaking happy
Start by getting more beerGetting ready to try and align my car. I have zero clue where to even start. It’s also hot and humid, I’m old and sweat like a lawn sprinkler and I only have 2 beers in the fridge. Maybe this is a bad idea…
I use the string method for setting toe, but I use a hub mounted alignment gauge for caster & camber. It works well enough, but I sure miss my access to a Bear alignment rack.some string and shut one eye!
Wow, 10:45 AM local and I just rolled into work, sat down, and got my Stangfix. What would it be like to be retired already?Two fans on and heat still got me so had to call it for the day.
I have the Longacre gauge and use this for the toe.Brian talked me through it. Got the Longacre gauge figured out, I’ve got -1.5 camber both sides and 3 drivers side an a little over 2.5 passenger side caster with no shims. Will start shimming and adjusting toe tomorrow. Two fans on and heat still got me so had to call it for the day.
