Re: I got my new 331 and it is installed..........Now a battery drain!!
For what it's worth, I had trouble with mine initially too... On the Cobra EFI intake, I was using the port all the way in the back on the passenger side and the thermoswitch would only occasionally trip to turn the fan on. On the Cobra lower intake that chamber is a dead end and figured there was an air pocket or the that the port was just too high to keep the thermoswitch in the flow of coolant. Moving it to the thermostat housing solved that problem for me.
"68EFIvert" said:The other thing is I ran the car up to almost 210 degrees and neither set of fans kicked on. I need to see what is going on with them. I did not dry test the fans before install so that is the first think I will do.
