Hint Hint...how I responded to Jeff
I believe the full name is Calamity Jane.1966 Ford Mustang Fastback named Jane. Owned by Her Highness Kelly Hattori
That is the formal name, but once you lay under her and pull her transmission to change out a worn out ring gear, you call her Jane.I believe the full name is Calamity Jane.
Let me know if you find a valve stem cap while you're down there.That is the formal name, but once you lay under her and pull her transmission to change out a worn out ring gear, you call her Jane.
Sure just go ahead and ruin my secret. No wonderIt helps when you can hover your cursor over the pic and up pops the pic info including her name!![]()
has issues with you!While we all knowSure just go ahead and ruin my secret. No wonderhas issues with you!
has plenty of issues I'm not sure he really has one with me. Well, other than his understandable jealousy, of course.51 Mercury Club Coupe.The next prize in our bag is ONE valve cap. It was at the bottom and I just found it, so.....
I heard the current resident just moved to an area south of San Jose. Can't miss the house it has a big yellow Chevy out front. Take your pick of valve stem caps.OK you win since the number of doors cannot be determined from the pic.
Your prize can be picked up in Modesto, California...address to be provided after blackmail letter is sent to current resident and response noted.
Mmm nice idea. I tried that once. Sold them as campfire starters. Did not turn out well.How can you afford all these valuable prizes? Next you will giving away used oil filters. With the residue oil..
