Centerforce diaphragm pressure plate and Centerforce 10.4" Dual friction clutch. Organic/ceramic.
. Discovered that I bought a pressure plate with a standard Ford bolt pattern Of course my fancy aftermarket flywheel has a different bolt pattern. Need to return the clutch and pressure plate and obtain one that fits. !!
You aren't seriously imply, in public no less, that you were right and i was wrong, are you?See TERRY, I told you.
You aren't seriously imply(ing), in public no less, that you were right and i was wrong, are you?
So for clarification purposes, what bolt pattern does that flywheel require?
Very cool tool, Mark. I didn't know something like that even existed. Now I want one and don't even have the need. It's a sickness.
Was your bellhousing in spec or did you need offsets?
