Well, I have been quietly working on the 70 boss 302 to get it ready to fire up after a 4 year sleep and have stumbled upon a startup issue which I'm not use to. Is it true that with a 70 mustang, you can only put the car into a steering lock position with a manual tranny if you put it in reverse?
The orange turd:
I have recently had the carb rebuilt, tested the fuel pump, etc. I do not trust the current fuel tank, nor hard line coming from the tank to the fuel pump, so for the test Im running a line from a 5 gallon gas can directly to the pump and then to carb. Once I get it running I will replace both the gas tank and hard fuel line.
The orange turd:
