I'm making these modified fuel fillers and it takes a lot of time hand fabricating the plates with tin snips. Do you have a plasma cutter and would it work for what I'm doing?
C-hair big would be cool, each filler is slightly different. The OD is roughly 2.25" they aren't perfectly round. I am cutting just about half way so I can get the disk in and fill the ID and I cut about a 1" wide slot in the bottom for support. This way if you really smack it good with the nozzle it won't bend. The smaller radius is to match the ID of the pipe. I'm cutting about 1.4" from the flange just because my sawzall can't get any closer. 3/4" would be better I think cause the tube is still pretty round but then the shape I have drawn might not fit."SELLERSRODSHOP" said:got the pdf, so have a good idea what you need. would it be best if i cut them just a c-hair larger in diameter so you can sand em down to fit each pipe. looks like the overall diameter is a hair over 2.25" with the 7/8" center hole & the notches in the lower half. how far down the pipe from the filler flange are you cutting the slot? may use mine as a test piece to get everything correct.
I'm open to anything. I am drilling the hole in a drill press. I have to mount the plate to a block of would so it won't wobble out the hole (early models look horrible). then hand cut, grind, cut, grind, etc. If I could have a bunch of disks roughly close I could crank these out pretty fast. I know electrician's have hole punch/cutters for panels that might work better and faster for the hole. I may look into one of those if I can get the right size. The drill bit I bought is perfect size to keep tight against the nozzle if it doesn't wobble (sorry to all the Ginny pigs who got early one's) My biggest issue I guess is I really don't have the right tools!"gotstang" said:Cool Craig, I forgot you was an injuneer...I envy folks that know AutoCAD. BTW I know a guy whose brother owns a CNC plasma...probably way too heavy duty for what you need tho.
thanks Jon!"Jonk67" said:Craig and Steve, if you guys need any parts shuttled back/forth I'll be seeing Craig on May 1st at Beach Bend if you need me to swap parts for ya'll.
Jon
"Fordication" said:I have a metal punch that I used for electrical boxes way back when. You drill a 1/4" in the metal then you use the punch to make the hole clean every time. THe size never changes and its a perfect circle. Now the outside would be a bit of a pain but if its 7/8" I will see if I have the right size and I can send it to you. I have not used the damn things since I got my degree way back in the 80s and they are just sitting in a well oiled box under my tool table.
Okay, I'll try to get it to you this week. Thanks again..."SELLERSRODSHOP" said:those punches are nice. had the opportunity to use those a couple times & they work great!
craig, with the offsets on the insert, it might be a good idea to get one to me to use as a pattern that i can hold in my hand. some of those figures are going to be hard to replicate like the .1039 & .1339. would be easier for me if i had one in hand.
