Shaun
I started out this year thinking I'll have a quite year on the development side but it got to early Summer and I was bored! To keep myself busy I blew up my motor, started designing a rear suspension, full floating rear end and this bad boy:
It uses the same giant 12"x1.25" directional curved vane rotor used in our Trans-Am kit but the caliper is a 4 piston forged aluminum piece. This caliper weighs less than half the iron one in the vintage kit. It has internal cross overs so no external pipe work to get snagged, stainless pistons and stainless pad abutments so the pads slide smoothly and won't gouge the caliper body. I'm going to offer the caliper powder coated red or black as standard but I can do any color if desired. The pads are .810" thick. Yes, that's correct, .810" thick. EACH. Each pad is the same thickness as a stock Mustang rotor! I also wanted the caliper rear of the spindle so ducting could easily be installed in the front.
As impossible as it seems it all fits under a 15" wheel. Our test wheel is the ever popular 15x7 Torq Thrust D, it fits with no wheel spacers and no modifications. A direct bolt on to the drum style spindle.
Will be available for sale in December. Price for a standard red/black caliper with plain rotors and street pads will be $1699. Options will include gas vented rotors and track pads.
