I'll have to see if I can find those flange bolts locally. I do have an upper plate that helps with the clamping force, and had planned on using a washer on a standard Gr8 bolt. It appears only one of the brackets has 1/2" holes and apparently that was from a little too much grinding/filing of the hole to make it smooth. The other plate has the correct size holes. Oh well, no biggie!
Below are some pictures of the raw assembly and then some of them installed. I did run into a slight issue in that with the motor at stock height and using my 1" lowering brackets w/o shims, I only have 1/2" clearance between the block and the top plate. This means that it'll only lower the motor 1/2" instead of the 1" that the brackets are supposed to allow. Somethings definitely screwy here! They were cut correctly (double checked) and measure out correctly in CAD, so I'll have to get out the old motor mount and double check my measured stock mount assembly heights :rp :rp :rp
One of the pictures below shows the stock rubber leaf spring bushings next to the final version. I had to grind down the dome so that it is close to being flat, and then had to cut down the bushing length since the width of the steel tube is narrower than a standard leaf spring.
Another mistake that I made was that I forgot to include the weld width in my intermediate/Tplate, so I have very little clearance to the weld for the locknut. I plan on using nylok nuts, but there isn't room for any kind of washer there. I'll be changing the CAD files so that the holes are slightly further apart, so that others won't run into the same issue.
Tomorrow I hope to sandblast the parts and then get them painted. It might be till Friday before I get to install the mounts to see if these lower the engine enough to get my correct driveline angle. Considering this is my real first fabrication job and very very minimal metal cutting skillz/tools, it's turning out half a$$ decent with exception to the few hiccups. I'll update with more pictures once they are painted and the motor is actually sitting on them :5
