"Shaun" said:Looking good.
Have you put any thought into up and down adjustments? If you built them as low as possible, you could use spacer plates between the motor bracket and the bushing bracket for height adjustment...
"65fast" said:That looks really good Jeremy! I am glad they worked out good so far. Are you making these with a 1" drop or standard height?
Can't wait to see the finished product.
"buening" said:Thanks! I will be detailing different shock tower brackets that will each lower the motor 1/4" at a time. I'm shooting for only 1/2"-3/4" drop in order to get the proper driveline angle. While your idea would work, you are essentially making the moment arm larger by using spacers and that location is IMO the weakest spot of the mount. I could be wrong though. The reason my triangular piece is so short is because I was trying to minimize the height of the intermediate "T" section, which also minimizes the distance from the motor to the bushing bolt.
"buening" said:I'll look into it Shaun. I'm a structural engineer, so I can run some calcs to actually see how much spacers affect it.
"B67FSTB" said:The way you did this took a lot of work !!!!! Respect!
I don't give any remarks on a job like this because of the hard work you put into this but if I may :
Those two plate in the lower left of the pics , I would make them longer so they support/reach more towards the engine
There is room for this .IMO
"buening" said:Keep in mind these plates are 3/8" (THICK!) and definitely won't be bending.
