Rest assured Ive spent an inordinate amount of time solving my engine cooling/space management problem. And thanks to you and Monkeystash (Ryan) Ive made progress. Ryan sent me this link last week:You are planning to use a shroud, right? Without one those fans will give a worse result than before as they physically cover less surface area of the radiator. A properly designed shroud will let them draw air across the full surface. Make sure when you are playing with your mock-up you are allowing for the thickness of the shroud as it stands off the rad.
I know you've likely accounted for all this stuff but thought it might serve to help others reading along that might not think of these points.
Slim-Fit Radiator System, Universal, Ford Style, 17-inch Core, Manual Trans | #69590-17
The basic concept of automotive radiators hasn't changed in more than 100 years! And fans have been hung onto them in a mish-mash of ways for just as long. Since then, aside from materials and design improvements, NOTHING HAS CHANGED...UNTIL NOW! PROFORM is upending the radiator industry with...
www.proformparts.com
though there is no direct replacement this model appears to be the most likely to be mounted in the engine compartment of my '65. Here is the link for pricing:
Proform Parts 69590-17 Proform Slim-Fit Radiator Systems | Summit Racing
Free Shipping - Proform Slim-Fit Radiator Systems with qualifying orders of $109. Shop Radiators at Summit Racing.
again, though pricey it will only require 4" of depth and has a integrated thermostat control. Snooping around on the Proform website shows that there is a wide variety of dealer outlets that carry this product. Im going with the easiest option first which is the Perma-Cool dual fan and relay install. If I need to add a shroud I will likely be switching to the ECP 2-core radiator you have in your Mustang.
ECP | No Gimmick Cooling
speedcooling.com
My final option is to go with an electric water pump and this ECP radiator/fan kit:
speedcooling.com
