stump
"2ndgen" said:I'd put a dab of grease on top of the stops, and I'd draw a thick chalk line all the way across the top of the wheel wells as a start... Another area that often rubs is the inside front of the wheel well, so a bit of chalk there too...
If the grease does not transfer to the top of the axle, you are not "bottoming out" the suspension; something else is causing interference.
-Rory
Ingenious. I'll try these out this weekend, thanks!
