I always enjoy seeing other peoples progress; So I thought I would share what I have been up to.
I made some repairs to both the frame and shock towers about 15 years ago when I was 17. It worked for the time but it has always bothered me. Once I started ripping into it I uncovered some work that a previous owner had done, Hidden well with sealer and undercoating.
Engine out and ready to start cutting....
First I removed the lower section of firewall and while doing so I ripped some of the metal on the inner rocker, partly do to some rust. I decided to remove a section and replace it.
As you can see it is rust free and still has it galvanizing, I put tape on it and then cut out the shape I needed with a razor..
This made a perfect template for me to cut out.
Primed and ready to install.
Welded.
Lower firewall/toe kick sitting in place
Welded.
