	There are all kinds of motion/flex involved. Why do you think they put export braces on our cars? There is more than enough movement happening between the firewall and apron to stress crack a line. If very rigidly mounted, even a hard stomp on brake can cause enough deflection int he firewall to cause issue."70_Fastback" said:But the Master is fixed to the same structural elements as the aprons, frame rails, etc. Why would the master move any more or less than the adjacent components. If that statement was true, wouldn't he need curly Q's at the 90 from the firewall to the passenger side apron as well?
There aren't any curly Q's in the fuel line and it fastens to the same points as the brake lines.
I'm not argueing your point, just wanting to expand on this issue some more... for my own personal use.
Secondary, on my rat, since the master cylinder is under the dash and I need to get the brake lines outside of the cab, I am thinking of doing braided flex lines from the master cylinder to the trans tunnel - extending fittings through the sheet metal and then coupling to rigid line at that point.
	"Horseplay" said:Instead of bending the lines down and around the frame rail, you could use whats called a "through-frame line fitting". This is how I will be doing mine where necessary.
	"65-408" said:Thanks, but in alot of ways we did it the easy way, start with all new. It is much more difficult and time consuming to cut in one piece at a time, while trying to save and reuse.
That's what I'll be patiently waiting to hear your comments on. I haven't decided which way to go with headers yet myself and any info on fitment will be greatly appreciated."65-408" said:It fits, but I havent tried the headers yet...
