yeah that was a thought but it doesnt show up til 70mph. At 60 mph its smooth as can be so i need to get her out some more and try to figure it outweird shakes ?? drive shaft imbalance ?
that is the plan. I may even swap wheels from the 69 stang to trySince you brought it up I'm guessing the "shake" is not minor. I'd spend the time to try and figure it out. Check to see if maybe you lost some wheel weights. They like to use those self-adhesive type now and if they don't clean the wheel well they are known to come off. Bad things can happen left unchecked.
I have UCAs, LCAs, Shocks, Springs, and Coil Saddles next on the agenda to go inHave you done a front end alignment on it? Could be the blame for the shimmy but even if not before you do any real distance driving its kind of a must or you could eat up that front rubber pretty quick.
Oh ive already ordered all the parts and ive done this all before on the previous mustangs....Just fighting it all really but youre right.....I just need to bite the bulletNever judge a spring just by appearance. Those old stokers might not only be "lighter" duty but also weakened with age. They might just accordion with only a little weight as compared to the new shorter, stronger springs. As long as you're in there I'd take a good long look at those UCA and LCA bushings etc. Whole lot easier to do it all now when the springs are already out. Once and done for a very long time. Not really a big expense either.
