we did some testing when I got home today. He rented a noid light to see if the injectors pulse and are not on all the time. We could also verify that the throttle position sensor works because while cranking if you open to WOT the injectors shut off. Both things checked out. I also wanted to see if the injectors might be leaking when not open so I pulled the fuel rails and zip tied the injectors to the rail. With them unplugged so they wouldn't open, we cranked the engine. No visible fuel. I know we had serious pressure cuz when I cut the first zip tie, the injector launched like a rocket!. Before I cut the zip tie I did plug one in and crank it. the spray pattern looked good. I wanted to test compression, but I loaned my compression tester to someone and don't recall who. It has never come back so I need to buy a new one.
In the mean time since we thought the fuel system seems normal we would look at other things. We (He) replaced all the PCV hoses and any other suspicious looking vacuum hoses but it still is hard to start or won't start and won't stay running if it does start.
So we thought while we do have spark, maybe it's weak. We borrowed the COP coils from the 99GT but they wouldn't fit in the DOHC valve covers. They have tabs on them to bolt down to the intake. The DOHC engine uses a cover to hold them in. So we put the DOHC COP coils on the 99GT. It did start but it was hard to start. It ran but it did back fire once while cranking. We shut it off and it didn't want to start again. So rather than flood it we put the 99GT COP coils back in and it fired right up.
So we may be on to something. COP coils and new plugs are going to be several hundred dollars but not a bad investment. He doesn't have the funds right now (he borrowed some from us to buy the thing in the first place!),but I think he will buy a couple per paycheck. With his discount he is looking at just over $400 for 8 coils, plugs and the boots.
