6-27:
Worked on the car until about 1 a.m. Friday night.
Got my new shifter handle installed.
Ran into an issue - the car wouldn't start. Turned out to be a problem with the range sensor on the transmission. Thought it was bad or I had messed some wiring up (neutral safety switch), but it just needed adjustment, plus the linkage needed dialed in a bit, which fixed it. Scared me for a bit though...
Got the cooler lines in. No leaks!
We got some transmission fluid in her and were able to fire it up & run the car through the gears on the lift to work the fluid through. Rear tires turned! Have reverse lights
Called it a night.
6-28:
Started in again around 8:30 this morning.
Got my new Auto console insert installed in the console. Got the console reinstalled. Also got a shifter boot from Classic Consoles on there since neither the factory 69 bezel nor the 98 Mustang bezel will fit for my setup. Looks good (IMO) with the 98 Mustang shifter (with billet T-handle)/69 console combo.
Verified my O/D lockout button at least turns on the light to indicate O/D has been disabled. Will have to verify with a test drive.
Got the cooler mounting/support brackets painted and installed.
Reinstalled my seats.
Cleaned & oiled my K&N air filter.
Changed oil.
All that remains is to top off the tranny fluid and take a test drive.
