I bought the .64. I have 3.25 gears now but plan a 3.70 swap.Which 5th gear did you get? I went with the .64 and really wish I would have gone with the .82.
The rpm drop between 4th and 5th makes my 460 very unhappy. So I end up only using 5th over 65mph. I have 3.50 gears, so I may change to 3.89's or 4.11's.
I wish you luck with the conversion. I had to raise the tranny tunnel 1.5 inches for good driveline angles. But I am using the MPG mounts, and I don't have the shaved tranny.
yes sir!Can't wait until you get this done. I want to drive itthis will bea completely different car than the manual steering auto I drove a few years ago.
hey son! was it hard to install? I haven't pulled the brake support yetI used that same kit.
since mine is an auto brake support it's in pretty good shape. Just not looking forward to remove it so I can cut out the bushings!!!Hey dad.
Not for a guy of your talents lol. Mine was pretty wallowed out so I had to weld the washer to the support.
