Mach1 Driver
As some are probably aware, there is a resistor wire in series with the ignition coil that is nominally 1.35 ohms. It lowers the voltage to the coil in normal operation to extend the life of the points. The wire is bypassed by the starter solenoid in START to give the ignition coil 12v, and makes the car easier to fire-up.
What I didn't realize about the wire is that Old Henry (in his in penny pinching ways) reduced the wire gauge to its absolute minimum- I mean it is REALLY undersize. I measured it in two 69 harnesses and found one to be 7 strands of .013, which equals 28 ga., and another that was 7 strands of .012 which equals 30 ga. The only way they can get away with this is because the ignition coil isn't on all the time, since the points are opening and closing when the engine is ON and running.
The exception is when the key is left ON with the engine stopped. The points will be closed about 2/3 of the time when the engine stops, so the coil will have constant voltage to it in this condition. Fortunately they are relatively short runs of wire and Henry just barely allowed for this. The problem arises when some smart guy changes the ignition coil to one with a low resistance primary- one of those really hot suckers with around 45kV of output. Instead of pulling 4.46 amps, now its pulling 6.46 amps, and that little old wire goes bye-bye.
Since Randy usually hangs out around here as a moderator, and nobody knows harnesses like Midlife, I'm wondering if this is a common gauge for the resistor wire from 1965 to say 1973?
