LastDeadLast
Well, after two days of toil in hot weather, I finally got my shock towers stripped and my shock tower reinforcement plates installed... mostly.
I started with a Pro-motorsports reinforcement kit for the 65 Mustang and after A LOT of messaging, I finally got it looking half-way good. Each piece had to be heavily modified to even come close and even then, there are pretty large gaps at the bottom of the wrap-a-round pieces. In order to make the setup a little stronger and to ease installation, I drilled 1/2" holes in the 1/8" plates and spot welded each piece to the tower. Next step is to stitch weld the top and bottom joints. I would have completed the job today but I ran out of welding wire.
Lesson learned:
Next steps are to finish the welding, grind the welds down, prep the engine bay and paint.
Here are pics of the progress so far:
I'll post more when I finish up.
-Shannon
Lesson learned:
- I should have sourced the metal myself and done this.. but cutting out the 1/8" steel would have been a pain in the ass.
- I know it's hard to get a pre-fabbed kit like this to fit every car, but I had to do a lot of re-bending and forming to get these pieces to fit right
- My welder, a Millermatic 211, kicks major ass. It did everything that I need it to and it makes spot welds like a champ
- I don't think I'll ever willingly want to do this ever again.. :barf
-Shannon
