Jonk67
Well the good news is I think this is the first bolt I've sheared from teardown to rebuild, even the exh. bolts and front leaf spring bolt came out with just some spray and torque. I'm glad this car was used it whole life instead of sitting.
Of course it happened after midnight when i had gained super strength from drininking beer all day working on the car. I checked the shop manual and the only spec I could find (that I could focus my eyes on) for the crank pulley bolts was ' Damper or pulley to crankshaft - 70-90ft/lbs. Well that seems like a lot of torque now for a 3/8" bolt but 2/3 clicked at 75ft/lbs. but not the 3rd....I can't find any torque specs for the crank pulley 3 bolts, any one know?
Now, do I do some careful centered drilling and pick up an easyout from my local Fastenal and give it a go on this new balancer or take it to a local shop and pay $X to have a pro do it, be done and continue installing parts? As you can see the hole goes all the way through so i think that makes it a little easier, wonder if I could soak it and start a bolt from the other side to help? There's nothing sticking up to grab and I don't know how clean of a slot I could cut into it with a dremel to try a flat blade screwdriver.
Jon
Jon
