OK...are you getting any spark out of the distributor? Bad rotor? Cracked cap? Missing coil to dizzy wire? Out of gas?
"AzPete" said:Not saying this is any help.....but why not check for spark at the plugs first....then work back from there. I always try to start at the last place the item is expected to work and then trace back to where things stop working.
So, why not stick a plug on a plug wire...crank it over and see if there is spark there. If there is, no issue with the coil or distributor or power to them.
Timing jumped¿¿¿
The rotor is spinning and I've already replaced the coil ( that was one of the first things I tried)"LATAMUD" said:If the cap is off it won't spark.
If the rotor isn't spinning, could be a broken timing chain, or chewed up cam/distributor gear.
If it is spinning I'd guess the coil went bad. If you have a spare coil or know someone that has a classic car that would let you use theirs to test your system that would save you buying a new one if only to test your system.
Yep..after market tach."Grabber70Mach" said:After market tach? If so it could be bad or shorting out to ground causing no spark. Had it happen to me in the past.
Tempting Pete...but then you would be back in the same boat you were in....crawling around these old girls trying to keep 'em running."AzPete" said:Let me grab my neighbors car hauler and get that old broken crate out of your driveway....no more worries for you. Won' t even charge you for hauling it off.....
Took the lead wire from into the coil and taped it to the fender apron appr. 1/8" from contact. Spun the car over a few times and no spark/jump at all."Opentracker" said:What I like to do when this comes up is pull the coil wire from the cap and lay it close to ground 1/8" to 1/4" and with the power on, spin the motor to see if you get a jump/spark. This test takes the cap, rotor wires and plugs out of it.
"70 StangMan" said:Took the lead wire from into the coil and taped it to the fender apron appr. 1/8" from contact. Spun the car over a few times and no spark/jump at all."Opentracker" said:What I like to do when this comes up is pull the coil wire from the cap and lay it close to ground 1/8" to 1/4" and with the power on, spin the motor to see if you get a jump/spark. This test takes the cap, rotor wires and plugs out of it.
I took the wire from the the coil and unplugged it from the cap. That was the way I took it."jims6t6" said:"70 StangMan" said:Took the lead wire from into the coil and taped it to the fender apron appr. 1/8" from contact. Spun the car over a few times and no spark/jump at all."Opentracker" said:What I like to do when this comes up is pull the coil wire from the cap and lay it close to ground 1/8" to 1/4" and with the power on, spin the motor to see if you get a jump/spark. This test takes the cap, rotor wires and plugs out of it.
Do you want the wire into the coil or the wire out to the dizzy?
Disconnected the tach...nada."Midlife" said:Although I doubt it, disconnect the tach and try again.
I guess I'll try a brand new one tomorrow. I took the one that had very few miles on it and had in my break down bag as a back-up and replaced the one I was running when she crapped out, but who knows maybe that one took a dive as well. At least with a new one it might change something."Midlife" said:Sounds like your coil or your input or output of the coil is bad.
