September 2008 Car of the Month- Dave Sanborn's '66
Sluggo
Here it is! Stanfix's first Pet of the Month. Da da da dah! How 'bout some stats Dave?
Re: September car of the Month Dave Sanborn
Oooooo Nice. I want one.
Thanks Sluggo! I am humbled though.... some of you guys have some really nice cars. Lauries "trouble", Darrelds 'vert and Jeffs '67FB immediately come to mind.
Stats? Really? You want to go down that road? Alright, you asked for it....
1966 Mustang FB modified (a little bit) to resemble a GT350 car. Other than the cars shell, which had all new metal installed, the only items left from the original car are some of the FG trim pieces in the back seat area, the back glass and the cigaratte lighter.
Engine and Drivetrain
-347 StreetFighter engine
-BBK SSI EFI w/70MM throttle body
-Stock T5
-AL driveshaft
-Narrowed 9" with 3.50 TracLoc
-Mustang Steve cable clutch
-Lokar gas pedal and throttle cable
Exhaust
-FRPP ceramic coated shorties dumping into R model style bullet mufflers and side exits
Heating/Cooling
-Factory heat system/NO AC
-Fluidyne HP series AL radiator
-SPAL pusher/Mech puller
Suspension/Brakes
-Front - Rod&CustomMotorsports MII with adjustable front coilovers, tubular UCA/LCA's and 1" sway bar
-Rear - Parallel 4 link w/Panhard bar and Chris Alston coilovers
-Power R&P steering
-Power disc brake booster
-Front 11" disc brakes
-Rear 11" disc brakes
-New 3/16" brake lines bent and routed
-Stainless braided flex lines at all 4 corners
Electrical
-Painless wiring
-Trunk mounted Optima Redtop in Taylor box
-Headlight Relays
-EFI
-Sony Explode CD player
Wheel and Tire
-'05 Mustang GT 17x8 wheels
-255/45/17 BFG rear
-225/55/17 BFG front
-Wheel spacer/adapters
Paint and Body
-The '66 FB shell is permanently mounted onto a one piece 2x3" boxed channel frame w/integrated DS safety loop
-2" tubular front frame rail to cowl braces
-FG Shelby style hood
-R model front apron
-Shelby style quarter windows
-Ultra White and Gaurdsman Blue BC/CC Dupont paint
Interior
-R model type rear shelf
-Roll bar/roll cage with hinged/removable side bars
-'04 Mustang leather seats
-Steering column moved 2" closer to the dash
-Six guage instrument cluster w/Autometer Phantom series gauges
-Simpson 5 pt. camlock restraints
I'm pretty sure I forgot a few things, but that pretty much sums up the parts. The car runs, drives and handles unlike any other classic Mustang I've built/owned. It's more like driving a modern Mustang than driving a classic.
I am glad to see you kept it somewhat original and kept the cigarette lighter. ;D My kind of car! Modded to heck and back!!!!!!!!
Hey Dave how do you like the 04 seats im planning to check out a power set this weekend.
was it a hard install what type of headroom did you gain or lose
Do you have any other pics of them
Or does any one have them in a 67 68 fastback?
These were a power set... at least the drivers side was. To minimize loss of headroom, the power seat track/motor was removed. Even with the motor removed, these seats sat too high on the stock risers. I had to remove the risers, knock them down an inch or so and then weld them back in. The stock '66 seat tracks (or 67-68) can be easily modified for use with these seats (by using some spacers).
These seats, IMO, look great in a classic Mustang. They're very comfortable and for the money, you can't beat the quality of a factory seat.
ok well i think i'll go pick that set up this weekend then as i need some seats that recline and look good to i'll just recover them in black vinyl later on
Can't wait to see it in person.
See it? Heck I planned on handing you the keys while I'm drinking down there. Just watch for speed bumps and keep the RPMs below 5500 and we'll be alright.
Dont'cha have a rev limiter on that thing Dave? Just dial her on down for the weekend... ~thu
I'm just curious, do you not like them? Or what's your opinion on them?
The easiest way to install a rev limiter is to run an MSD box and throw the 6000 RPM chip into it.
Since I'm not running an MSD box, it becomes more difficult. Correct?
I did not know, off hand, that you were not running an MSD box.
I actually had a new MSD 6AL kit sitting on the workbench. If I hadn't gone EFI, I would have used it. Once I started messing with all of the EFI wiring, I brought the MSD kit back. It seemed "un-necessary", and from a seat of the pants feel, I can't see how the MSD would have bettered the stock ignition system.
Downside to all of this.... no easy rev limiter.
How about a MSD DIS4? It may help the ignition. I am guessing its a waist spark ignition.
