southern_boy
So I have a couple of projects going on and I was wondering if I should go ahead and rewire them just to be safe from possible fires early in the future? And also if EZ Wiring Harness's would be good to use if I did decide to.
"Jonk67" said:I had a Mallory like that in the '80's that the coil wire went into a hole in the top where you see the coil post. There was a cover that unscrewed, you would cut the coil wire to get a bare flat end, slip it through the cover and push it down on a needle type post to make contact then screw the cover back down which would keep tension on the wire so it wouldn't slip out. I think the cover had and O ring.
Look for a phillips head screw on the top or better yet post us a pic instead of making us guess...
Jon
"AzPete" said:Jumper wire from the pos. battery to the ign. side of coil. Crank car with key. If it starts, you will have to pull the jumper wire to shut it off. This tests the coil and gives a possible test of the wiring.
