It's been awhile since I got the chance to post any progress. I took the last week off of work and other than a day or two of intermittent rain, the weather cooperated. Part of my time was spent fixing little projects, of which there were a bunch of. This included a small patch to the left rear wheel well, two patches on the lower right rear window opening, a patch the the right side of the rear window opening and rebuilding the the trunk lock area on the rear deck lid. Seems some yahoo decided the best way to open the trunk without the key was wrench the whole cylinder assembly until it opened, but bending and tearing the metal in the process. It was a bear to dolly the area flat because it's so difficult to get to the back side of the metal when working it. A little creative application of various junk laying around was used as spoons and dollies to get in behind it solved the problem. Then I had to weld up the tears.
Here's the finished deck lid:
The areas circled are where the window opening were patched. Considering this was originally a vinyl top car it was (pleasantly!), surprising there weren't more bad areas!
The forward area of the wheel well actually required two patches, one over the top of the other. It was just a matter of trimming them out and welding in new metal:
Then the big fabricating project, which I saved it until last. I got a late start one day so I spent my time doing straight fab work. The rear end of the right rocker panel was gone. Initially it appeared just to be deep pitting. The more I probed, the worse it got. I really didn't want to spend $60 on the outer rocker just for a short section so in typical cheap bastage fashion, I made it! The ironic thing is I knew I had to repair the lower quarter at the seam. Last year I bought the patch panel. After finishing up the fab work on the rocker patch I then matched up the store bought patch to see how the seams would look. It then struck me, why in the WORLD did I buy that patch. :wtf Fabbing it would have been child's play compared to the rocker patch! Oh well!!
Here's the finished patch:
I don't have a "before" shot of the rocker. I thought I had taken one before cutting it open. Afterwards I discovered I didn't hadn't taken one! Once I got the outer skin off, it got worse! The inner area (which is actually part of the outer wheel well), was also rotted out. I spent all day yesterday rebuilding that entire area. With this being my last day off before going back to work I got the rocker and lower quarter patch finally installed. Here's the finished results:
I have "new" doors for both sides so fear not about that rotten area in the pics!
While it may not seem like a lot of work for over a week off, I lost a couple of days due to honey do stuff and running around for supplies. I also lost a day and a half to weather. What I didn't shoot pics of yet is what else I was working on. That was fitting the section in the battery tray area for the factory 5.0 air box. Yes, I'm doing it the hard way and using the entire factory air intake system, including the silencer in the fender well (and yes, I know you pick up a few HP without it!). It's almost finished but I consider it a modification as opposed to a repair. I spent almost an entire day on it and it's close to being done. Rain threatened the next day so that's when I switched gears to all the little repair projects. I'm also moving the battery to the driver's side so I'll be modifying that apron too. Other than that, all I have left to repair is the sail panels on the roof. Then all the sheet metal mods AND repairs will be completed. Ooops, forgot I have a driver's door to skin too! Stay tuned!
