"Midlife" said:Sounds to me like one of your leaf springs is shot, and everything else is a band-aide to correct that flaw. Those tire sizes are well within the design parameters of the Mustang for 1966 (I've run exactly those two sizes without issues), so there has to be another problem.
"stump" said:What do you think, swap springs to the other side and see if it reverses the lean/rub?
"Midlife" said:First, I agree with AZPete: go back to as stock as you can and go from there.
If I were you, I'd spring for the $250 and buy a new set of leaf springs if you can't find anything obvious.
"Midlife" said:Wait a sec! Didn't your body man screw up your car? Could they have swapped out one leaf or some other component?
"AzPete" said:Another thing to look at....
Park it on a level floor and lift it off the ground...no wheels touching. Support it from the front frame rails and the rear frame rails just in front of the rear axle. This leaves the rear portion of the frame rails free of any pressure except body weight. Check the rear frame rails for being parallel...
A 1/4" in one place can really screw things up 2' away.
"stump" said:My near-term plan...
Replace the right (shortened) shackle with another +1" (since I have another one here), and see how it sits with two equal size.
