70_Fastback
Hell Bent for Speed
I'm doing my 4-link setup this weekend. What is a recommended rearend pinion angle - or does it just need to be set parallel to the transmission pinion angle?
Some types of rear suspensions offer more control than others and require different angles. According to Bickel, a ladder-bar suspension normally requires ½ degree of pinion angle, a four-link requires 1-2½ degrees, and a leaf-spring suspension requires up to 6 to 7 degrees. In all examples, were talking about negative pinion angle, i.e., the pinion is nose-down in relation to the driveshaft.
"daveSanborn" said:Jeremy,
When you state:
Do you mean you're welding all the brackets onto the frame/rearend? Welding the brackets should be a straightforward process and a LOT simpler if the arms of your 4link are adjustable. I'm unsure which arms you're using, but the arms I have use long shaft heim joints that screw into the arms. This allows the length of the arms to be adjustable to make infinite changes to the pinion angle. What type of arms are you using?
