Old Timer Help for Old Timer Tool - P&G Valve Gapper
swpruett
Howdy folks!
I am a sucker for “old” tools. Particularly tools I was “raised” with and have since gone the way of the wagon in the modern sense.
Recently, I picked up a very nice P&G Valve Gapper, nearly identical to the unit I was trained to use many years ago. If you know what these are and how they work, you’re my kinda crazy! There really has never been another tool like it to ensure extreme accuracy in setting valve lash on mechanical cams and it’s a shame they have become so rare.
Anyway, as someone who continues to have need to set valve lash, and hates the feeler gauge method, I decided to try to find the most complete P&G Valve Gapper I could. This is a “Universal” model 300 which was considered the most “flexible” evolution of the design before they went obsolete in the early 70’s.
As I have a desire to better round out my setup to cover all of the engines I get into, I am looking for some help in locating and purchasing some specific P&G parts if anyone might be willing/able to help. Specifically, I am looking for the following:
Adapters (horse shoes): H-1, H-2, H-3, V-2, J-5, F-1
Barrels: #1
If anyone has any familiarity with these tools and has any leads on where I might find these bits, I would be very grateful! I have a small cache of Model 300 parts I have that I can trade if anyone else out there might have one they still use as well. Just let me know what you are looking for!
Thanks!
I'm far too young to have idea what this contraption might be about but I will be happy to keep an eye and ear out. ;)
I had to go see if I could find a video of this thing in use. So here is a brief one for anyone interested.
Thanks Terry! I didn’t want to admit that I had no idea what it actually did, but since you claimed the First Dummy spot I don’t mind riding in on your coat tails. Thanks to the video I am now educated!
Here’s another good one explaining a bit more about the advantages of the tool (and in use on a Y-Block of which I spend most of my gapping time):
I love trick tools and am normally pretty anal about this kind of stuff but this one's too far over the edge even for me........
Howdy folks!
Barrels: #1
Thanks!
View attachment 34457View attachment 34456
Just saw your request. I have a model 300 which has the No.1 inner barrel as well as base adaptors F-1 and H-1 among others.
I am looking for Inner Barrel no.6 and Base Adaptor K-1 if you have them.
The Model 300 is killer but yeah, finding those specific adapters is rough. Ever try reaching out directly to engine building communities? Sometimes people sit on this stuff forever and never think to sell until someone's actually looking.
Old tools are cool. :cool: I rarely find P&G parts, but once in a while in teh bottom of 'junk' parts at swap meets. I'll keep an eye out now that I know some lovers are here.
For those wanting to use the method, I use the same/similar method using stuff I already have. In this case, a dial indicator with either a magnetic base or clamp (vice grip) mount. The way I do it is:
  • Set the dial indicator over the valve tip with the stem in-line with the valve (location #1 in photo).
  • Press down on the tip of the rocker (2) or lift the heel of the rocker (2) to get zero gap, and set the dial indicator to zero.
  • Lift the rocker tip or press down on the rocker heel to read the current gap. I may gently use a thin wedge tool (small screwdriver) between the stem tip and rocker (#3). The right tool will sit in the gap and hold it up hands-free for rocker adjustment.
  • Adjust and re-check.
That's it. The P&G system is still valid and slick today, but if you don't have the tool you can still enjoy the quick and accurate adjustments.
If you don't have a dial-indicator setup (useful for many types of checks), they are available in quality "good enough for this" online under $40 for either type:
