Just finished posting this freshly finished project for COTM. Finished it at 2am, did a 3 mile test drive then got up at 4:30am to trailer it to the Mustangs Plus show.
Have a couple bugs to work out. Oil & fuel gauge readings.
Oil Pressure reads barely to the low side.
Fuel gauge doesn't really move.
Have tested both gauges by grounding and they both go all the way up so they should be OK.
Running new style instrument cluster voltage regulator.
Water Temp gauge seems to be working great.
4.9 volts to all 3 sending unit leads with key on.
Oil Pressure Gauge
-Grounded lead at sending unit and gauge will rise all the way up.
-Tested oil pressure while running with an external gauge and pressure is 60 psi.
-Installed a new sending unit tonight, no change. Used correct type for gauge not light.
-Ohms test from stud on sender to body of sender showed no change on both the old and new units but the same test on the sender on my '65(has gauge not light) and on a spare(different thread size) show a change in ohms doing same test although way different numbers for each.
-Should the ohms reading change when checking from the stud to the body?
-Could it be that the new Borg Warner unit I just bought form O'Reillys is bad right out of the box?
Fuel Gauge
-New 22 gal '70 tank with new '70 sending unit.
-Put 5 gallons in for the 30 minute cam break-in run, gauge might have moved a little but honestly our focus was on other things at that time.
- Put in another 10 gallons after the cam break-in, gauge still lays below E.
- Car has only 80 miles on it now so I figure there should still be at least 4-5 gallons still in there even if we burned 3 gallons in during the break-in and 10-11 in the 80 miles(using rate of 10 mpg).
-Checked with meter from body of sending unit to fuel tank screw, reads there is continuity.
Realizing that the ground test might only prove that the unit is ground to the tank(e.g. the mounting screw might have good contact with the tank but not the body do to strip caulk between them) I checked to the body but didn't get a change and will admit I didn't dig too hard as I hate to scratch all the hard work painting the floor pan. Would testing by running a wire from the body of the sender to the - post on the battery be a good idea?
Don't really just want to put a bunch more gas in to see what happens only to have to drain it to pull the sender to bench check it(which is what I know we may end up having to do any way).
Thoughts and ideas?
Oil Pressure Gauge
Fuel Gauge
Thoughts and ideas?
