Hey all,
Thought I would run this issue by you all.
I have a 66 with an A code 289, aircon (not fitted), power steering and a new 3 core radiator with deep shroud (back edge level with the back edge of the fan blades). Also have a 160degree thermostat fitted)
Have had many issues with overheating but since installing the shroud and having the timing (mechanical advance mechanism) fixed the engine has not overheated once.
Only thing is now, the temp steadily rises with speed, say I am driving at 35mph, the temp needle (standard issue) sits at about 1/5, then as I increase speed, say 60mph the needle with head north to almost midway.
The question is, should the temp be operating in this manner?
Cheers
PNYGTA
Cheers
PNYGTA
