Thanks, I will try that!"bravenrace" said:Heat the bolt and then let it cool. Heating the bolt is easier and more effective than trying to heat the balancer, plus there may be rubber on the back side of the balancer holding the inner and outer halves together (Honda sometimes uses this type and sometimes doesn't). Obviously you are correct that heating the bolt expands it, but it also breaks up anything that might be preventing it from loosening. Once cooled, it should come right off.
