That's why I'm here"Jonk67" said:Yeah, with the roots style you'll probably need a hole in the hood too to clear the blower and carb. You may want to also consider the Paxton centrifugal style, a little easier to live with but you'll need a blow through carb. A blower will also require lower compression like 9:1 or so or lower, any idea what your compression ratio is? This'll change the cam you will want to use too.
You really need to plan out your whole motor and drivetrain, plan your work and work your plan.
Jon
