And Kat's ammeter will not be hooked up to anything."tarafied1" said:3G wiring
who needs an ammeter?"Midlife" said:And Kat's ammeter will not be hooked up to anything.
well there ya go..."Kats66Pny" said:My ammeter doesn't work anyway.art
How do you know your ammeter doesn't work?
You just installed a new dash cluster from Johnpro, and haven't started the engine with the new wiring in place, right?
"Midlife" said:I believe you should be able to have the two pulleys exchanged...
"AzPete" said:There could be a difference in the alternator fan based on the direction the alt. was originally designed to run.
I do not remember if the amp gauge on that cluster did not work (did we check it Mid?) or if it was just because it was not hooked up so I would not have seen it function. The car had a 1 wire I believe so it would not have been hooked into the system....but the memory is getting old.........
