When doing a hard, nearly panic stop, Midlife stops at first straight, and about 2/3rds the way through the braking, the rear end slews to the right.  The steering wheel stays straight, so I suspect the rear breaks.  AZPete found a minor issue with my rear brakes a few weeks ago, and we adjusted the drums by hand using the star adjuster.  Since I found the problem, I backed up in reverse hard several times, and I found the problem diminished some, but not entirely.  I suspect one drum is still over-tightened, probably the left.  Does this sound right?
Also, I found the car on the highway now tends to veer right if I don't have my hands on the steering wheel. Our roads are not entirely level, and I suspect the crown may be causing the problem. Generally, I have to keep a slight amount of left control on the wheel while driving, but it is barely noticeable. Could the two problems be related?
