tarafied1
:Mark saw this on the inter web, is it yours?
"KBMWRS" said:Maybe your car was upside down?
"SELLERSRODSHOP" said:don't give him any ideas.... :steer
"KBMWRS" said:Quick block drain of coolant?
"tarafied1" said:did you use "water wetter" or any kind of additive? I use water wetter and 15% antifreeze in my 429 and it runs cooler than it did with 50/50. I've been doing this for several years with no ill effects.
"KBMWRS" said:Water alone is a better conductor of heat than water and coolant. Coolant's main purpose is for anti-freeze properties with lubrication and rust prevention secondary.
LOL"65coupei6" said:Huh?? Is someone using Mike's logon? I can't image those words coming out of his mouth. Sounds to knowledgeable.bj
that's why I do it. the engine does run cooler."KBMWRS" said:Water alone is a better conductor of heat than water and coolant. Coolant's main purpose is for anti-freeze properties with lubrication and rust prevention secondary.
"tarafied1" said:that's why I do it. the engine does run cooler.
I know some tracks don't allow antifreeze because if it spills on the track it's hard to clean up/slippery. I was just wondering about the additive. I run the recommended 15% but was wondering about using no antifreeze.
