"AzPete" said:...powder up and go for a ride.
"apollard" said:Exactly what are you guys discussing again? :lol
"guruatbol" said:My money is on the rear of the pan. It is an easy in car fix too. I did it on our 67 when I dropped a socket in the dizzy hole!
"RustyRed" said:If it really starts ticking me off I am half tempted to buy some of the UV dye and a black light![]()
"RustyRed" said:get your mind out of the gutter :lol :lol :lol
"apollard" said:Me? you're the one laying around with mirrors :scar
and a rolled up twenty dollar bill!!!"RustyRed" said:mirrors and powder....don't forget the powder :lol
"RustyRed" said:I've noticed a spot of oil once or twice and I've been trying to chase it down.
Think I know where it's coming from now. It seems to be coming from around the transmission inspection plate. If I wiggle the inspection plate it's "wet" for lack of a better way to put it.
It's oil for certain and not tranny fluid.
I think I know the answer but any chance it could be anything other than a rear main seal? I checked where the heads meet the block and no signs of leaks there. Didn't think to check the back of the intake though.
Motor only has 200 or so miles on it so I am a bit po'd that it's leaking oil from anywhere. It's not a massive leak but still pretty annoying.
"buening" said:If you have the spare change I would recommend getting the one piece Felpro PermaDry oil pan gasket. Be sure to use the 4 push-pins into the block to hold the gasket in place while you raise the oil pan up. No sealant is needed with that gasket and it is reusable over and over.
"sigtauenus" said:And you never get it as pretty again either after you booger up the bolts taking stuff apart again.
