Sure. Just stay clear of the hood hinges.
I might put the filter mid way in the line where it is more under the regulator.
"buening" said:If you would prefer to unclutter the engine compartment, put the filter just after the electric fuel pump.
"daveSanborn" said:I'm fairly certain that you'll become quickly frustrated trying to use a saw to cut through steel braided line. The teeth of the saw snag on the individual pieces of braiding and it usually makes a mess. A cleaner method of cutting braided line is to use a high RPM cutting wheel.... such as your dremel tool.
"turq66" said:Dave, how do you change that filter without taking a gasoline bath?
"buening" said:Kat, that picture that Dave has was exactly what I was recommending, and no you don't have to jack the car up to do it. Jump on a creeper and slide underneath the car below the gas tank.
"Kats66Pny" said:I just went and looked and there is no way I could fit on a creeper under there to reach the electric fuel pump area. And no I'm not fat. :lol Maybe whenever I have a little texas repair party, I'll let someone else mess with it though!
"daveSanborn" said:I can slide under my gas tank laying on a creeper... and I'm not fat either, just "big boned". Just saying.
"daveSanborn" said:Kat, I sometimes wonder what you'd do without our helpful advice. Once again I'm here to rescue you.
Before you slide under the car on your creeper, outstretch your arms to let any protrusions settle down to your sides... then slide under the car.
"Kats66Pny" said::lol well... um.. how do I say this... my plastic surgeon didn't make them so they can hang that way.
