I started my car to move it out of the garage and it sounded like all he** had broke loose. Turned it off and the engine kept cranking. Tried moving the ignition switch around...no change. Dang starter solenoid is frozen! :censored
What to do? What to do? Started to release the clutch and car was lurching forward...put it into neutral. Starter then began grinding against the flywheel! Jumped out of the car, grabbed a wrench, opened the hood and disconnected the negative battery cable...problem stopped
Smoke filled the engine bay from the starter and the battery cables getting so hot the insulation melted...could have started a fire if I hadn't disconnected the battery in time!
I WAS VERY FORTUNATE THAT THIS HAPPENED AT HOME AND I HAD ACCESS TO A WRENCH TO DISCONNECT THE BATTERY...MAJOR WAKEUP CALL!
GET A BATTERY DISCONNECT SWITCH! :thu
I really hope my flywheel is OK.
