A
Anonymous
and then he woke up from his fantasy and went :doh
"68angrypony" said:Hi all,
I'm new here and new to classic mustangs. I have a 68 and I have been wondering what are my options to change out the fueling process. My car doesn't move yet so I have no idea how the stock filling works out. But here are a few questions I have:
Is their a way to delete the filler neck and just fill the tank some how from inside the trunk?
Yes, many track cars do this
With this mod, you can still have fuel get onto your paint?
Of course, you still need to get the filler into the trunk area, you can still get gas on the rear taillight panel, it will drip...
Is it possible to change from a 68 screw on cap to a pop open or lockable cap? will this make a difference in fueling? Yes, they bolt on the same way
I have a coupe by the way and am just curious as to what I can do to make fueling easy and keep gas off the future paint ;-) Coupe, FB and Convertible are all the same when it comes to fuel system
"KBMWRS" said:When you get to...or close to perfection (in your eyes) please let us know.
I'm interested too.
when you say leak, do you mean it leaks into the trunk? Or splash back thru the filler hole? I left a small spot unbrazed at the bottom for a "drain" so fuel wouldn't stay there between the new plate and cap. I may eliminate that and/or the hole I drilled in mine. I get some splash from the hole on mine if I let the pump auto shut-off. I don't know if that drain is totally needed."Fast68back" said:I have mine installed and have one fill up under my belt since. I still have a small leak, but I think its because that one spot on the bottom wasnt brazed. I have the one I took off if you want I can send it to you Craig, or next time you fly through DFW you can pick it up.
