definitely make sure the number of teeth are the same...other than that, bolt 'em up."95GT" said:Yep it will work fine. Just make sure you have the right bellhousing for the flywheel you are using. There are two different size flywheels. One has 157 and the other has 164. If you do not have the matching bell your starter will not work.
"68bucks" said:My current crank is the original in my 71 engine and has been taken to .10
