As most of you know, I'm in reassembly mode on my 67 project, and some days are much better than others.
Bad day: getting the first scratch on the new paint.
Good day: successfully installing my first headliner
Well last weekend, I'm bleeding my clutch setup and when I finally build up pressure, I feel a pop and shift of the clutch/brake pedal assembly. :wtf
As it turns out, the roller bearing kit I installed slipped out of position, which popped the snap ring out of it's groove. Now I have to partially disassemble the dash, disconnect the brake master cylinder and remove the steering column to extract the pedal hanger... ugh.
2 steps forward and 3 steps back... :mj
I tore it all apart last night, and this time I tack welded the roller bearing in place on the hanger. Gotta love doing a job more than once!
What's the biggest setback you've had on your Mustang project?
