I'm sure those of you who own 69 and up Mustangs have experienced problems with the dash cluster circuit card: broken traces, poor contacts, etc. I have had customers go through 3 reproductions before they have found one that worked. Enough is enough! I asked myself: can the dash cluster be hard-wired with a multi-pin connector?
Someone provided a 71 dash cluster for me to work on. Here's what the back of it looks like with the flexi-card on it:
The desire is to minimize modifications and make a new harness plug-n-play. There's no means of using the existing connector with the rounded contact tips, so a new connector pair must be made. There are 14 lamp sockets, and these are 1/2" holes, not the standard size for 1895 or most 194 bulbs. I found a wired replacement socket and went to town. Here's what the final product looks like:
And here's my testing of the entire assembly using a 12V power supply:
The dash lamps are lit, believe it or not. The diffusers are what suck up the photons.
For 1971-73, I can build the dash cluster harness and a pigtail for those who want to splice their own wires for $100. For the same amount, I can add that to your existing harness.
I need to find a 69/70 dash cluster to use as a template, so if anyone has a beater laying around, let me know.
