"buening" said:Thanks!! Could you measure the distance center to center of the arms just below the hanger steel? Go ahead and grab the measurement between the pads just in case. If I'm measuring 6" and you are measuring 4" (assuming you measured center to center of the arms), that means I have to make up 2". If I have 2.75" between pads, then that would only leave me with 0.75" of clearance if I try to bend the pedal to obtain the 4" arm-to-arm.
Let me know if you are measuring the distance between the pedals (clear distance) or center to center.
