well if the torch will "melt" the spring enough to cut it, it will soften it too.
"jonward786" said:". . . you would have to heat these things at 600 degrees for 5 hours to damage them"
"jonward786" said:Take a look![]()
You can calculate from the spring's motion ratio and the loaded coil spacing (use the center distance between adjacent turns) to get a pretty good idea where it'll end up. If anything, you'll tend to end up a little high, rather than a little low."jonward786" said:I thought others would benefit from seeing how much of a drop 1/2 a coil gives so they could decide how to cut their own.
I've got to give welder bob at least partial credit here. And not everybody on the 'net flat-out disapproves of using a torch to do this . . .I didn't cut the coils myself because i dont have those kind of tools (yet). I ran down the road to a machine shop / welder and asked him to cut em with a low heat method because i didnt really want to bust out the hacksaw. He goes "why can't i just use a torch?" I replied, "Well ive read heat could damage spring rate, so if you have a cutting wheel or something, could you just use it?" He goes "Whoever told you that is an idiot, you would have to heat these things at 600 degrees for 5 hours to damage them" I just smiled and said "No torch please". So i guess everyone on the internet is wrong according to welder bob, haha :shrug
If by "riding better" he means that the ride quality during easy driving on reasonably good roads does not stiffen up, he's right about that much. Cutting springs does stiffen them slightly. But being more likely to be whacking the bump stops when the driving gets more enthusiastic or the roads get worse generally equals a poorer ride."guruatbol" said:Our suspension guy at the shop told me when I asked him to cut my front coils, to just heat them up.
He said that one - you don't remove them and two the car will ride better and align easier. he told me to never cut the coil! I have to ask more when I get time, but I am thinking of having him do it while we are slow. He does tons of suspension work.
I think when I get the 65 dumped an inch I will post pics and all the reasons to help.
