Can I drive without grease?
"stangg" said:
Is it an illusion, or is the front wheel not centered on the wheel opening?
Most likely not an illusion. It has all new suspension front to back and is going for an alignment on Friday. I was futzing with the lower arms and strut rods to get it at least driveable yesterday so I can take it to the alignment shop (it had about 10 degrees of positive camber when I first sat it down and moved it around). So most likely I cranked on the strut too much.
LOL.
I hope you did not adjust the strut rods to correct your 10 degrees of positive camber. :hide
All buttoned up and ready for an alignment.
I ended up with 1/2 coil removed in total.
I lost the light...and the outside photos on the drive sucked. But I drove it around the driveway and the pulled it back on the lift to get a good side shot photo.
So....grease or not, it will not move....that perfect stance is only going to happen while you sit on the side of the road waiting for a gas can to drive up......what good planning.....lol. Sounds like some of my days....
Or maybe when it is full of gas....and then I sit my fat ass in the front it will all balance out :shrug
