SELLERSRODSHOP
took a little time this weekend to start the cleanup on the gt-40p motor that going in the tr-4. i decided that since all the hoses,sensors & injectors were ruined in the fire to scrap the idea of keeping the EFI on it for now. long term plans are to eventually find a good H.O.  motor from a mustang & use the shortblock to build for my mustang & use all the fuel rails injectors etc. on the explorer EFI since mustang parts are needed to use the aftermarket harnesses.
i removed all the crusty EFI stuff & picked up a really nice almost new edelbrock performer rpm intake for $100 yesterday. also started cleaning up the mess on the outer surfaces of the block/heads etc. had one lower intake bolt that snapped off, but there was enough left sticking up to weld a bolt to & get it turned out.
i'm trying to decide if i want (or need) to change cams. i figure now would be the time to do it since i'll be replacing the timing cover & already have it torn down to a bare long block. taking into account that this car only weighs 2000 lbs, & the stock 4 cyl put out 100 hp vs. the 210 rated on the stock gt-40p, should i upgrade to a stock H.O. mustang cam or one of the ford "303" series cams? here are the specs i found for the stock explorer cam :
Intake: .422", Exhaust .448" (measured valve lift)
Intake: 256*, Exhaust 266* (actual duration, NOT at .050")
116* lobe seperation
For comparison, the stock 5.0 HO cam:
Lift Intake: .444", Exhaust .444"
Duration Intake: 266*, Exhaust 266*
ford racing E303:
Duration 282/282
Lift .498/.498
ford racing B303:
Duration 284/284
Lift .480/.480
any recommendations? the motor will be backed up with a t-5 & a narrowed 8.8 rear.
ford racing E303:
Duration 282/282
Lift .498/.498
ford racing B303:
Duration 284/284
Lift .480/.480
