Hey Guys,
I've been reading up on cams/timing, and where I should set mine, and I've just confused my self. Just to refresh your memory:
DSS Ford 306 Roller block
GT40 heads
Comp cam - 35-324-8.
Summit 600 CFM carb.
MSD 6al with matching Dizzy
This cam is rated at 218 intake 224 Exhaust. 270 lift.
So Iam starting at 10-12 degrees with the timing, but It's just not running correctly, I hear pinging, and loss of power over 2K RPM.
I've also read that maybe I should back the timing back to as low as 6-10? I have checked the Dizzy, and TDC - and did realize I was off a tooth, that helped a lot.
Any advice?
But I did find this article which was very informative:
http://www.carbdford.com/viewtopic.php?t=5543
GT40 heads
Any advice?
