no it was cold i put in 4ltrs run the motor to fill up convertor then added some more and checked dipstick until i got the right amount in switched car off found a big puddle under car ,the trans was totally dry when the previous owner fitted it."midpack" said:Simple question, but... was it hot and running when you checked it before you put fluid in?
over fill i dont think so i put in at least 10ltrs"AzPete" said:Rear seal, shifter seal, lines to cooler, vacuum modulator, pan gasket.......front seal. Did you over fill it?
will jack up car tmrw and check trans lines etc and also convertor drain plug and bellhousing for signs of leaks"AzPete" said:I think they take 9 qts. when dry. Run it and see where it is on the dipstick.
and running..."AzPete" said:I thought you check it in park.......warm......
"GT350" said:over fill i dont think so i put in at least 10ltrs
