Battery hold down - another POS part
sigtauenus
My car hasn't even been driven yet and I already have "new" parts that have failed and need replaced again. WTF?
The battery hold down is about 2 years old or so, and the rubber coating on it is pealing back from the top of the handle with rust/corrosion on the metal underneath. I use those red and green washers on the battery and there is no corrosion at all on the battery itself. Actually I recently changed the battery to an optima, but regardless, there was no corrosion on the other one either.
What gives? Is this something I just have to accept or does anybody have any tips on how to keep this from happening. I know its about a $5 part, but it still drives me nuts to see that.
Yes, the repro battery hold-down is prone to exactly what you described. It may be easier if you removed all of the coating and then cleaned and painted the metal.
Thank goodness I'm not the only 68 owner who is encountering with POS repro parts.
:craz
After reading this post, I pulled mine out of a box where it had been for 2 years. The coating is cracked and peeling off. What a piece of $%!)!
So yours is brand new and never even got installed and its coming apart? Sheesh. What a load of crap.
My first car was a 67 coupe that I got when I was 16. I sandblasted the battery holddown and then used that liquid rubber stuff you get at the hardware store to coat plyer handles and what-not (comes in like black, red, yellow, etc) and it lasted a good 6 or 8 years doing that. I should have just done that again.
