Marti bought a license to use Ford's data base. The data provided by Ford may or may not be precisely correct. Marti sells reports that are supposed to accurately relay Ford's data. When Marti is asked to prepare a report on a particular car, they are relying on that Ford data so the question really is: "Is Marti's report an accurate reflection of the Ford data?". I suppose it is conceivable that someone at Marti made a mistake when researching Ford's data and the report reflects that mistake however, given the low volume of requests, it is probably an extremely remote possibility.
A few months ago I posted about a car that I am working on for a friend who has owned the car for 41 years. The door tag is original to the car and it contains an data impossibility, an error by Ford when the car was serialized. That error lists the body type as a deluxe interior car yet, shows the trim code as a standard interior....it can't be both. In fact, there must have been some confusion on the assembly line as most of the deluxe interior pieces were installed on the car but not all.....some of the deluxe hardware was actually found under the carpet having never been installed. The Marti report confirms that Ford's data is consistent with the deluxe interior that was mostly assembled on the line so someone screwed up when the data tag was produced and that screw up apparenlty caused some confusion during assembly that I discovered when disassembling the interior for the first time since the car was built. At this point, there are no plans to have a correct data tag produced though the missing courtesy lights have been installed under the incorrectly installed door grills and connected to the correctly installed but up until now, unused courtesy light harnesses.
